BS270, is it a logic level MOSFET?
Discussion in 'General Electronics Chat' started by atferrari, Mar 27, 2012.
  1. atferrari
    Thread Starter AAC Fanatic!
    Jan 6, 2004
    2,663
    783
    In this site, third paragraph, they said the BS270 is designed for logic level input.
    In the datasheet I could not find anything suggesting that.
    Is it or it isn't?
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    Here is the Data Sheet...
    http://www.fairchildsemi.com/ds/BS/BS270.pdf
    I think it is, but the data sheet is unusual in that it does not come out and say so directly. Usually this is a selling feature, so I am a bit uncertain.
    One thing though, data sheets are always your friend.
  3. ErnieM
    Apr 24, 2011
    7,435
    1,625
    The data sheet calls out the Gate Threshold Voltage when VDS = VGS, ID = 250 μA to be a min of 1 volt and a max of 2.5 volts.
    Yes, that makes it a logic level FET.
  4. nickelflipper
    Jun 2, 2010
    280
    35
    The BS270 looks very similar to the 2N7000 datasheet, only better power handling characteristics, definitely logic level. Also, the pinout is reversed from the 2N7000.
  5. jwilk13
    Member
    Jun 15, 2011
    228
    12
    It is logic level, but I'll ask everyone else this just for the OP's reference:
    Should he be concerned that Rds(on) is not specified for any Vgs below 4.5V (if he were considering using 3.3V to turn it on)?
  6. crutschow
    Mar 14, 2008
    13,473
    3,361
    From the data sheet I would say it works ok for 5V logic but not for 3.3V logic, which is barely above the threshold voltage.
  7. Audioguru
    Dec 20, 2007
    9,411
    896
    When its gate-source voltage is logic-level at 4.5V:
    1) Its maximum on-resistance is 3 ohms.
    2) Its drain-source voltage drop is 2V when its current is at least 400mA.
    Is that good enough for your circuit?
  8. atferrari
    Jan 6, 2004
    2,663
    783
    I have no circuit in mind AG.
    I realize that maybe, in 1995 there were not so many logic level MOSFETS, at least described as such...
    Thanks to all replying.
