The classic use of the term is irrelevant. A transistor is a transistor, a BJT is a transistor, as is a MOSFET, that's why it's in their names.Note the BS170 is a MOSFET, not a simply a transistor in the classic use of the term.
I just wanted to clarify for the OP the part inquired about is a MOSFET. I have found we often refer to BJTs on AAC as simply transistors and call out MOSFETs. While true both BJTs and MOSFETs are transistors, each operate differently.The classic use of the term is irrelevant. A transistor is a transistor, a BJT is a transistor, as is a MOSFET, that's why it's in their names.
That is why they need to be explicitly stated.I just wanted to clarify for the OP the part inquired about is a MOSFET. I have found we often refer to BJTs on AAC as simply transistors and call out MOSFETs. While true both BJTs and MOSFETs are transistors, each operate differently.
You are correct on all points. I couldn't recall the correct term for the commonly used transistor until you mentioned it (BJT). I've just seen the BJT transistor more often than not referred to simply as transistor on AAC. I will be sure for my part to make this distinction in the future.Saying transistor instead of BJT is plain lazy and makes for a confusing conversation. A new member will not know that distinction and may become more confused. As this is a site for learning and disseminating information, I think it pertinent to be explicit whenever possible.
Thread starter | Similar threads | Forum | Replies | Date |
Switching laser diode with BS170 MOSFET | General Electronics Chat | 3 | ||
B | Cascaded BS170 common source & feedback | General Electronics Chat | 2 | |
J | quick question on a Bs170 | General Electronics Chat | 1 | |
Mosfet buffer with BS170 or J201 or similar. | Analog & Mixed-Signal Design | 1 |
by Aaron Carman
by Jake Hertz
by Jake Hertz
