brushless motor speed control
Discussion in 'General Electronics Chat' started by fwks, Jun 7, 2012.
  1. fwks
    May 17, 2012
    12
    hi everyone,
    is it possible to control the speed of a brushless dc motor using picaxe40X2? if yes, how do i deal with the hall sensor commutation?
  2. shortbus
    Sep 30, 2009
    4,096
    1,692
  3. KMoffett
    Dec 19, 2007
    2,584
    234
    If the motor already has built-in electronics for commutation and speed control, like most small cooling fans do now...I'm pretty sure you can't.
    Ken
  4. mcgyvr
    Oct 15, 2009
    4,791
    976
    You could try using PWM then a low pass filter to smooth that out.
    A straight PWM signal will just cause it to stall/not start/just oscillate back and forth,etc..
