Good day all
Planning to use brushless RC motor as a simple generator to charge my onboard batteries (which die after heavy flights, as one could expect..) during the flight.
So will drive the brushless motor on the same axis from the petrol engine. I just purchased a simple sensorless brushless motor. It has 3 wires, and I'm not sure if it is Delta or Y winded. But regardless, I'm planning to connect 3 phase rectifier and capasitor, then voltage regulator, 7805
Will this simple set up work ? Or do I need to modify and custom wire the brushless motor (not sure how easy this will be , considering the size of the motor....)?
