I am not that good with some motors hence the question.
The motor is used in a washing machine. This the same type
The Armature is fried. The sparking is too much and eats up the brushes.
The label is in Chinese but googling around I believe it says
AC 220-240V 50/60Hz 1400rpm
Wash 4.0A , 50W
Spin 3.0A, 300W
I am trying to figure out the stator winding.
The inductance measured does not add up. I think it may be due to series parallel combination issue. I am not sure. Looking for an expert advice.
I like to know the two winding details since I think the two power rating is used and the three wires indicate two running conditions. I like to replace the motor and need to know the details to find a compatible motor.
I have two motors but the wiring is different from outside. I need to take the working ones apart to figure out the stator winding.
Another problem is the working ones rpm is 12000 ??
And another one that only says 220-240VAC, 480/17000RPM ??
I think the second one is two speed one but the rpm is way too high. Don't you think ?
