Broken scriber?
Discussion in 'Off-Topic' started by spinnaker, Dec 6, 2015.
  1. spinnaker
    Thread Starter AAC Fanatic!
    Oct 29, 2009
    5,062
    1,160
    Never had a scriber before. I ordered on form eBay for the purpose of making it easier to drill PCBs .
    It just came in and I noticed that the point comes out easily. So easy in fact that you can't take the little plastic cover off that covers the point without pulling the point out of the tool. Is it broken?
  2. strantor
    Oct 3, 2010
    4,302
    1,989
    Sounds like its defective to me. But I would need to see exactly what you bought to confirm.
  3. MaxHeadRoom
    Jul 18, 2013
    10,824
    2,495
    Beware of ANY tool made in China, if yours is, I try and refuse to buy any hand tool made there, The quality I found is terrible.
    If you intend making any extensive use of any tool, buy quality is my motto.;)
    Max.
  4. JohnInTX
    Jun 26, 2012
    2,391
    1,051
    Several of my scribers have removable tips that are secured by twisting the threaded collar around where the tip shaft goes into the handle. Does yours?
    And I agree with @MaxHeadRoom . The only time a cheap tool will let you down is when you are using it.
  5. spinnaker
    Oct 29, 2009
    5,062
    1,160
    No this one sort of just slips in. If I can get my scanner to work I will post a picture.
  6. Alec_t
    Sep 17, 2013
    5,954
    1,131
    Being a skinflint I'd probably just use a stout sewing needle epoxied into a short length of tube (e.g. ball-point pen casing). Perhaps adapt a retractable ball-point pen?
  7. spinnaker
    Oct 29, 2009
    5,062
    1,160
  8. GopherT
    Nov 23, 2012
    6,297
    4,019
    Drill a hole and add a selftapping screw to make a set screw?
  9. GopherT
    Nov 23, 2012
    6,297
    4,019
    Or crimp it wth a vice or similar.
  10. spinnaker
    Oct 29, 2009
    5,062
    1,160
    Guten tag
    Holder is cast. Doubt it will crimp. I only paid $3.00 for it so no big deal.
  11. GopherT
    Nov 23, 2012
    6,297
    4,019
    Super glue?
  12. spinnaker
    Oct 29, 2009
    5,062
    1,160
    Was thinking that. I have some epoxy I can try.
    GopherT likes this.
  13. MaxHeadRoom
    Jul 18, 2013
    10,824
    2,495
    Starret Machinist Scriber.;)
    Max.
  14. spinnaker
    Oct 29, 2009
    5,062
    1,160
    What does that mean??
  15. MaxHeadRoom
    Jul 18, 2013
    10,824
    2,495
    It means an answer to last a life time.
    Starret have been in the hand tool business since 1880.
    I still have my old mic from my apprenticeship.
    Max.
  16. ISB123
    May 21, 2014
    1,240
    531
    Thats really bad build quality. My scribers are made from solid piece of hardened steel.
  17. spinnaker
    Oct 29, 2009
    5,062
    1,160
    Well it cost less than $4. ;)
  18. MaxHeadRoom
    Jul 18, 2013
    10,824
    2,495
    No, but equal to after buying the four that break when you use them! :p
    Max.
  19. GopherT
    Nov 23, 2012
    6,297
    4,019
    It is an experiment, not a production setup. And he is poking dents into a piece of copper coated plastic. A sewing needle stuck into a piece of cork to protect his hand will be just as effective - he doesn't need a Starret Tool to be effective.
