Broken power supply
Discussion in 'General Electronics Chat' started by PZUFIC, Sep 25, 2015.
  1. PZUFIC
    Jan 7, 2012
    23
    Hello!
    I have a broken switching power supply. I accidentally push a striped wire inside the case and made a connection from FET heatsink to the case. The FET heatsink is connected to the ground of a input bridge. FET case is totally insulated from heatsink. It's a 5 and 12 V Traco power supply.
    I shorted out thermistor and polyfuse, remove varistor and replace broken bridge. Then I tried it on a autotransformer. The current was low at the beginning of rising voltage, but then if it just went up and burned the resistor, which is connected between source and bridge ground. I removed the FET and tested it. My AVR tester recognized it as double diode. The method with DMM failed and also method with 5 V power supply pot and 100 Ohm resistor, there was no current going into the drain.
    Does anyone have experience on that case, what can also be a common problem?
    Is there any common replacement for mdf7n60b FET, because this one is kind of hard to get.
  2. #12
    Nov 30, 2010
    16,705
    7,355
  3. Hypatia's Protege
    Distinguished Member
    Mar 1, 2015
    2,850
    1,317
    Inasmuch as the 'FET' is of the insulated gate type (i.e. a 'MOSFET' as opposed to a 'JFET') the result is indicative of failed gate 'insulation' [at least]...
    It would seem you may purchase the device here:
    http://www.aliexpress.com/item/Free...F7N60-SSS7N60B-7N60C-MDF7N60B/1892086767.html
    EDIT: Please heed post #2 --- Mouser is a reliable vendor!!!:):):)
    Best regards
    HP
    PZUFIC likes this.
  4. KeepItSimpleStupid
    Mar 4, 2014
    1,289
    225
    Switchmode supplies don;t really like auto-transformers. Some require at least a minimum load on the highest power supply.
    I would, however use an incandescent light bulb in series with the line.
    Sometimes without the minimum load the voltages keeps rising. 10-20% full load should work.
    The light will limit the power and act as a current dependent resistor.
    Bridge blowout is common and so is the FET
    PZUFIC likes this.
  5. PZUFIC
    Jan 7, 2012
    23
  6. Hypatia's Protege
    Mar 1, 2015
    2,850
    1,317
  7. PZUFIC
    Jan 7, 2012
    23
  8. Hypatia's Protege
    Mar 1, 2015
    2,850
    1,317
    Putatively, yes -- That said; you are advised to compare the maximum and application critical specifications of any replacement with those of the OEM part...
    Best regards
    HP
    PZUFIC likes this.
  9. Aleph(0)
    Member
    Mar 14, 2015
    358
    347
    Say what HP? No New Tone equivalent?:p
    I say mosfet at link will work cause absolute maximum ratings ok and on resistance is lower and gate charge and parasitic capacitance favorable for switching service
    PZUFIC and Hypatia's Protege like this.
  10. #12
    Nov 30, 2010
    16,705
    7,355
    Obsolete? The whole page? Twenty-five different 7N60 transistors in stock by the hundreds? Some in stock by the thousands...You call that Not Available?
    Hypatia's Protege likes this.
  11. Gdrumm
    Aug 29, 2008
    684
    36
    Girl fiight?
    (Aleph (0) and HP?)
    ...Whatever she said...
    Aleph(0) and Hypatia's Protege like this.
  12. ian field
    Oct 27, 2012
    4,459
    792
    The MOSFETS may be insulated from the heatsink, but the heatsink is often connected to the negative end of the bridge rectifier. On a 230V mains; that usually means about 320V negative half cycle peaks.
    You should start by taking the MOSFETs out and test whether either are shorted, I'd also examine the PCB looking for vapourised tracks.
  13. Hypatia's Protege
    Mar 1, 2015
    2,850
    1,317
    'Tho no shill -- I must confess - did NTE list an 'equivalent', I would have mentioned it - albeit with the caveat that substitutes are 'iffy' at best and never preferable to proper replacements --- All of which is to say, I concur with Aleph in this instance...:)
    Best regards
    HP:D
  14. MaxHeadRoom
    Jul 18, 2013
    10,860
    2,525
    Depends on the OP's CoO.
    In Canada for example, DigiKey is just about the best bet.
    The trouble with NTE they are upwards of 4x the cost usually for a sub device.
    Max.
