Broken laptop connector Thinkpad SL400
Discussion in 'General Electronics Chat' started by Leigh, Apr 30, 2011.
  1. Leigh
    Feb 11, 2010
    20
    G'day all,
    This connector seems broken to me, as the plastic locking part has separated from the body of the connector. I couldn't figure out the orientation of the locking part until I started this message. Now I think I have. It has clicked in nicely. I'm worried that it isn't very secure because of the broken bit, so have used a bit of sticky tape to hold the cable to the board.
    Now I have found the same problem on another connector. Same solution. This laptop has suffered at the hands of a previous attempt at repair by the looks. The power socket, which was loose in the body of the laptop, has loose wires, bad soldering, with broken location lugs in the body. A good old bit of Aussie "bush mechanics" is all I can do. Here's hoping.
  2. marshallf3
    Jul 26, 2010
    2,358
    201
    Use lots of a glue that decently hardens to hold them still after you've corrected the solder/other messes.
  3. Leigh
    Feb 11, 2010
    20
    I dobbed a bit of "liquid electrical tape" on it, 'cos it might have to come apart again one day. Life's a compromise... fingers crossed.
