Hi, earlier today, I tried to turn on my tv and after it finally responded to me touching the touch sensor power button, it made a very loud popping/cracking sound and then lost all power (even standby). i immediately unplugged it, and when i replugged it, it comes on standby but will not turn on. this happens every time i try unplugging and replugging the tv. after some research online, i took the back cover off to examine the components. i had read about problems with the power output board, lots of times caused by bad caps. i also read about main board troubles but i assume that was not my problem because it turns on standby. anyway, i have found what seems to be residue or gunk caused by whatever components that popped, and have already ordered a new power output board... but now i am not so sure and am looking for a more experienced opinion on what the substance is; it could be glue. it appears on several spots around this board, but only on this one board in the tv.
note: it is a dynex DX-L40-10a LCD tv. a notoriously cheap company, apparently. also, i have yet to drain any caps or touch anything on the board as a result. i also do not have a multimeter to give readings.
anyway, on to the pics:
i will take any other picture requests
