Hi All
Before I post this I browsed around to find out if it was discussed before and found this link:
http://forum.allaboutcircuits.com/showthread.php?t=64123&highlight=chess
which would be a very good starting point as some of my questions have already been answered there but I will have to re-read this for further understanding and questioning.
First I want to go one step backward and plan my design and stick to it!
BTW, I am trying to make a robot that would be able to play chess!
Here's the high level design block diagram I came up with based on the discusion in the above link as seen in attachment hlevel
Any comments or better suggestion?
second, I decided to break the above high level into different modules to design separately and to be assembled later (attachment mod1, mod2, mod3). I have categorised them into hardware and software modules.
The hardware ones has the following ones:
module1 --> design of chessboard & pieces
module2 --> design of the controller to move pieces
As for module2, I am thinking of design an arm that would be used to move and lift the pieces...But this seems to be the most difficult one for me!!!
And I could not even come up with a good block diagram for it...
The software one has:
module3 --> implementation of Chess engine (on a PC) and all that goes with it.
(still researching/investigating on this one)
Third, the possible different interfacings between these modules:
1. interfacing between module1 and module3: I read somewhere (can't remember) parallel port would be easier,...
2. interfacing between module3 and module2: serial cable, bluetooth,...
3. interfacing between module2 and module1 (how are the board and the controller 'arm' attached together? this would be mechanical I guess)
Any suggestion on the different interfacing and their advantages (would definitely choose the one that would make my life easier)
The system would also have the additional software modules:
module4 --> communication protocol between module1 and module3
module5 --> communication protocol between module3 and module2
Anything missing in my design strategy?
All comments are welcomed!
EDIT: Attachement removed!!!
