My project requires that I be able to power it with a 12 VDC supply. My 12 VDC can come either from a battery or a rectified AC source depending on the availability of a source. If I connect a battery directly to the output of the bridge rectifier (no AC available on the input of the bridge), do I hurt anything((bridge, battery, transformer) or do I need to isolate the bridge when the battery is used?
