Here are the conditions:
Function Generator:
Freq: 1.00 kHz
Vpp: 2.00V
CH1: Vac (Function Generator, input)
Ch2: Vr (Resistor measurement, output)
I've heard that if you split the ground (using different grounds) for both the resistor and the diodes, that this should fix the problem but it does not work for me.
Any ideas what I may be doing wrong?
Function Generator:
Freq: 1.00 kHz
Vpp: 2.00V
