Bridge Rectifier Problem
Discussion in 'Homework Help' started by Plague, Oct 3, 2010.
  1. Plague
    Oct 3, 2010
    [​IMG][​IMG]
    My main concern here is how to find the transformer ratio and Vpeak
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. Georacer
    Nov 25, 2009
    5,151
    1,266
    You should start with the voltage you need to get the requirements, then add 1.4V for the voltage drop on the diodes. This way you will have the voltage required at the secondary of the transformer and will be able to caclulate the turn ratio.
    Do you have the Sedra/Smith Microelectronic Circuits? It has plenty of formulas that describe thoroughly the full-wave rectification.
