Bridge rectifier overheating (moved)
Discussion in 'General Electronics Chat' started by oinkieporks, Jan 17, 2016.
  1. oinkieporks
    Jul 12, 2014
    14
    hi same here i'm working on with my power supply giving a 5v output. the transformer that I used was 220v primary 12v-0-12v 3a, the rectifier I used was 1n5408 then the capacitors after the rectifier were 1000uF and 0.33 uF after that 7805 (though it can only carry 1a I give it a try) then 0.1uF. what went wrong? though when I tested it 7805 didn't heat up but later on I noticed that the rectifier heats up and I saw smoke. Good thing nothing blows up.
  2. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,388
    You just hyjacked an exixting thread:
    Now you have a thread of your own.
    If you want help, post a schematic and a picture of the setup.
    Bertus
  3. dl324
    Distinguished Member
    Mar 30, 2015
    3,378
    651
    Post a schematic and indicate which diode smoked.
  4. oinkieporks
    Jul 12, 2014
    14
    here is the schematic of my power supply
  5. oinkieporks
    Jul 12, 2014
    14
    the diode that smoked was the 1st one. here is the actual photo of my connections
  6. dl324
    Mar 30, 2015
    3,378
    651
    Don't see anything wrong with the schematic, or what I can make out from the breadboard (except the small caps should be ceramic).
    Your breadboard doesn't have the transformer connections.
