Bridge Rectifier not giving same output as input
Discussion in 'General Electronics Chat' started by BluePhantom, Dec 21, 2015.
  1. BluePhantom
    Nov 16, 2015
    20
    I have connected a bridge rectifier (KBPC5010 - www.danomsk.ru/pdf/159613.pdf) to an AC source of 25v 40Amp
    and a filter capacitor rated 70V 4700uF in parallel with DC output.
    but the DC output when measured with a voltmeter is only 4v whereas the input AC voltage is 25v.
    I cant figure it out
    RRITESH KAKKAR likes this.
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    You might have the meter on the wrong setting for measuring AC Voltage. It is an easy mistake to make.
  3. BluePhantom
    Nov 16, 2015
    20
    Nope
    AC setting was 200VAC
    DC setting was 200VDC
  4. spinnaker
    Oct 29, 2009
    5,076
    1,177
    Post your schematic
  5. R!f@@
    Apr 2, 2009
    8,791
    771
    Bad bridge.
    Capacitor connected reverse.
    Meter bad.
  6. spinnaker
    Oct 29, 2009
    5,076
    1,177
    Bridge connected wrong.
  7. R!f@@
    Apr 2, 2009
    8,791
    771
    that too.
    edbog likes this.
  8. Papabravo
    Feb 24, 2006
    10,340
    1,850
    What kind of meter has settings for both AC and DC simultaneously? It should be one or the other. What kind of meter is it?
  9. BluePhantom
    Nov 16, 2015
    20
    circuit diagram-
    And my multimeter is allright
  10. R!f@@
    Apr 2, 2009
    8,791
    771
    Check your bridge.
  11. spinnaker
    Oct 29, 2009
    5,076
    1,177
    I would verify it is hooked up correctly and your bridge is working.
  12. BluePhantom
    Nov 16, 2015
    20
    ok ill get another bridge and will check it out..
  13. dl324
    Distinguished Member
    Mar 30, 2015
    3,378
    651
    If your DVM has a diode check function, you can check the one you have.
    PeterCoxSmith likes this.
  14. panic mode
    Oct 10, 2011
    1,328
    305
    also check if your AC source is low impedance (tripped breaker for example?). maybe what you measure is just leakage current.
