Greetings,
Im a bit of a Noob here but here it goes:
I have 2 sources, both 24VDC. Actually one is 27VDC off the charger and the other puts out 24VDC. One is a battery and the other is a converter. I have installed a bridge rectifier but hooked it up as to be an isolator for the sources. (See photo, battery charger not shown)
The problem I have is that I get 38V at the end of the circuit BEFORE I close the breaker. AFTER I close the breaker, I get 27VDC (same as the battery with the charger on it). Any ideas of what the problem may be??
This looks like it should be an easy one looking at the other posts.
Thanks,
Josh
Thanks,
Josh
