bridge diode rectifier
Discussion in 'General Electronics Chat' started by kdnaushad, Feb 3, 2004.
  1. kdnaushad
    Feb 3, 2004
    I am trying to derive equation of a circuit with inductance placed at the output of a bridge diode rectifier and a capacitor is placed in parallel with a resistice load. So can you help me derive the equations of inductive current, average output voltage, harmonics of output voltage and input current.
    Thank you.
    kdnaushad
  2. mozikluv
    Jan 22, 2004
    1,437
    :) hi,
    are you trying to make a switching regulator? or a power supply with the use of a choke coil. tell which one and i will give you the formula to use. :)
