Bridge circuits - just need help with this notation
Discussion in 'Homework Help' started by galway, Jul 9, 2007.
  1. galway
    Jul 9, 2007
    I'm studying for my PE (licensing) exam, and I need help with this problem. I don't need help solving it (at least not yet), just with the way it's drawn. I've never seen a circuit with arrows coming out of the nodes like this. I'm guessing that they're supposed to be currents entering or exiting the nodes, but I was hoping someone here would know for sure. I'm supposed to be solving for the current across R5, if that helps any.
    Thanks for any help!
  2. JoeJester
    Apr 26, 2005
    3,393
    1,211
    I couldn't access your pic. If it's small enough, just upload it on the forums.
  3. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
  4. galway
    Jul 9, 2007
    Sorry about the pic, I've attached a slightly modified version.
    So taking the sources and sinks, I'm supposed to use Kirchoff's Law to solve for the current across the load. Note that the bridge isn't balanced.
    @A: 100 - I1 + I4 + I5 = 0
    @B: -20 + I1 - I2 = 0
    @C: -50 + I2 - I3 - I4 = 0
    @D: ID + I3 - I5 = 0
    If I assume that all of the sinks are going to the same place, then ID would equal 30A, but that still leaves me with 5 unknowns and only 4 equations. What am I missing?
  5. galway
    Jul 9, 2007
    Anyone? :(
  6. recca02
    Apr 2, 2007
    1,211
    see if this gives u independent equations:
    express currents in terms of voltages at nodes.
    u might get equations something like (R1I1+R2I2)/R5 = I5;
    see if this helps.
    1 more thing Id shud be 30A since no accumulation of charge takes place in the bridge.
  7. techroomt
    May 19, 2004
    198
    galway - interesting problem. don't think i can help you other then i think
    equation c should read: I2 - 50 - I3 - I5 = 0
    equation d should read : ID + I4 - I3 = 0
    how do you start variable elimination? multiple loop equations?
  8. galway
    Jul 9, 2007
    Thanks for the suggestions, I'll try them this weekend.
  9. recca02
    Apr 2, 2007
    1,211
    post if u do get/(or not get) answer along wit doubts.
    as in my earlier post u wud get your 5th equation from the idea that voltage at two points is same for different branches.
  10. hgmjr
    Jan 28, 2005
    9,030
    214
    The condition for a balanced bridge is for I5 = 0.
    How about setting I5 = 0, then you will have four equations and four unknowns.
    I tried this approach and was able to arrive at ID = 30 amps.
    I guess this is the same thing as saying that the fifth equation in the mix is I5 = 0. This equality is dictated by the goal of balancing the bridge circuit.
    hgmjr
