break coil current
Discussion in 'General Electronics Chat' started by m121212, Dec 18, 2014.
  1. m121212
    Thread Starter Active Member
    Jul 24, 2011
    71
    I'd like to break the current of a relay coil in response to a comparator going high.
    I have an idea on how to do this, but it's not very elegant and I wanted to see if there were any better ideas.
    My idea is to use the comparator output to trigger a bistable 555 which then disables a FET in series with the coil.
    I guess what i'm looking for is perhaps some semiconductor like an SCR that changes state and stays stuck that way. (Once the coil is tripped the comparator will go low again). The SCR however gets stuck on. I'd like something that gets stuck off.
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    Something latches the relay initially (manual button?) Now the comparator puts out a momentary pulse that unlatches the relay until the next time it is manually latched again?
  3. MrChips
    Oct 2, 2009
    12,635
    3,454
    You just need a relay with multiple contacts.
    Use one set of normally open (NO) contacts in series with the relay coil.
    Then use a push button to manually energize the relay.
    alfacliff likes this.
  4. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,521
    What sets the relay on initially?
    Max.
  5. MrAl
    Distinguished Member
    Jun 17, 2014
    2,556
    515
    If possible you should use a reverse connected diode for the coil too in order to help reduce contact arc over when the relay opens.
  6. #12
    Nov 30, 2010
    16,693
    7,334
    Maybe something like this?
  7. m121212
    Jul 24, 2011
    71
    #12 - I did think of using an SCR to pull the coil current like you've drawn. The disadvantage though is that you're shunting the full coil current to ground, and that can be significant for a larger coil. It would be preferable to have a zero current latching shutoff.
  8. m121212
    Jul 24, 2011
    71
    Max - good question. Imagine the user applies a power supply to the relay coil to close the relay. I have access to the coil terminals and can interrupt/break that current (with the right circuit!)
  9. #12
    Nov 30, 2010
    16,693
    7,334
    Meh. Just an idea. That's why there are several of us here. Lots of ideas.
    You could have an SCR latch a driver transistor off to use less current, but SCR's have a minimum hold current. If you want zero, it can be done, but not with an SCR.
  10. kubeek
    Sep 20, 2005
    4,689
    806
    How about using a latching relay?
  11. m121212
    Jul 24, 2011
    71
    That's not an option, the relay is already spec'd and it's a non-latcher.
  12. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,521
    I have used a similar method in the past with LM311 , if the output of the the comparator is set to arm a 2n7000 fet that has a N.O. momentary P.B. in series with the drain and the relay coil, a N.O. contact on the relay is wired in parallel with the PB.
    If the comparator output is set (armed) the PB will set the relay on and the relay contact will keep it retained until the comparator changes state, the circuit will remain until the cycle is repeated by the PB.
    Max.
  13. Alec_t
    Sep 17, 2013
    5,972
    1,135
    Does it have spare contacts that could be used for latching?
  14. kubeek
    Sep 20, 2005
    4,689
    806
    Not THAT relay, I mean use a latching relay instead of the triac or whatever. It will keep its setting after power loss and will not require any current throughout the whole time, except for the brief moment when you wish to disable the main relay.
  15. ian field
    Oct 27, 2012
    4,447
    791
    The easiest way to commutate an SCR when running on DC; is another SCR - the second SCR has a pull-up resistor from anode to Vcc, the 2 anodes are connected together via a capacitor. When your control SCR is latched, its end of the capacitor is pulled down to 0V, the other SCR is off so the pull-up resistor charges its end of the capacitor to Vcc. When the added SCR latches, it pulls the positive end of the capacitor down to 0V - the negative end of the cap then tries to go below the 0V rail. This takes the SCR current down to zero (and then some) so it unlatches.
  16. m121212
    Jul 24, 2011
    71
    Oh I see. That's a good idea. I'd like to avoid another relay however, and if possible, go all solid state on the control.
  17. m121212
    Jul 24, 2011
    71
    I'm having a little trouble visualizing this - what drives each gate?
  18. m121212
    Jul 24, 2011
    71
  19. ian field
    Oct 27, 2012
    4,447
    791
    Given the circumstances - perhaps the comparator could drive a C/R differentiator to produce a narrow spike to fire the gate.
    Or possibly a long period astable multivibrator to periodically reset the circuit - you could use the differentiator or have a very uneven mark space ratio on the multivibrator to give narrow reset pulses.
  20. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,521
    The circuit in #12 is only four components including the comparator and relay.
    Max.
