Breadboarding fine pitch chips and surface mount chips how?
Discussion in 'General Electronics Chat' started by relicmarks, Apr 29, 2008.
  1. relicmarks
    Thread Starter Active Member
    Oct 13, 2006
    355
    How do i breadboard or prototype fine pitch chips? and surface mount chips?
    Since they don't fit into the breadboard pins how would you guys do this?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    I would do the breadboarding with through hole devices and save the SMT for the printed circuit board.
    It is becoming harder to do hobbyist electronics because so many IC's are becoming hard to handle or impossible to breadboard.
  3. relicmarks
    Oct 13, 2006
    355
    How would i use through hold devices? on the breadboard?
    What through hole devices are you talking about please?
    I thought "through hole device" was just regular resistors,capacitors that just had solder on the top layer and bottom layer with a through hole conductor hole in the middle
  4. relicmarks
    Oct 13, 2006
    355
    When trying to do continuity checks with a ohm meter if i place my red or black probes on the FIne pitch ic chips its DAMAGES the pins
    Is the best way to wrap a ZERO ohm resistor around the probes on the RED and another zero ohm resistor wraped around the black with tubbing over the zero ohm resistor leads so you can put your fingers on them to not add more resistors or creats a false reading??
    Cause when i'm using a oscilloscope probe for testing fine pitch IC pins inputs and outputs the probes lead are way to BIG for the fine pitch leads so would using a zero ohm resistor wrapped around the probe lead is easier to probe around fine pitch pins
    How do you guys use the DVM meter and oscilloscope with fine pitch IC pins?
  5. jpanhalt
    Jan 18, 2008
    5,699
    909
    There are a variety of adapter boards made for SMD. Check under prototyping supplies at your favorite vendor. Some come in large sheets, that you can break apart for single devices (see: Jameco, Velleman), others are more specialized (see: http://search.digikey.com/scripts/DkSearch/dksus.dll?Selection).
    In general, you attach your SMD to the board, add pinheaders for the contacts and can then treat the SMD as a standard through-hole device. There are even solderless "sockets" for SMDs, but they are a bit more expensive than the route I just described.
    John
  6. jpanhalt
    Jan 18, 2008
    5,699
    909
    I use somehting like this (http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=501-1179-ND), but I didn't pay anywhere near $10 each. They were probably about $2 to $3 each. That listing in Digikey must be an error, or Ponoma doesn't intend to stay in business. What I like about them is that they are tiny, and they grab from both sides so they don't slip off like the single-hooked ones seem to do. John
  7. relicmarks
    Oct 13, 2006
    355
    Some are called "smartboards" right?
    The smartboards have solder solder trophs right?
  8. relicmarks
    Oct 13, 2006
    355
    SMD Test Probe and SMD Test Lead
    Tektronix KlipChip Adapters
    Minigrabber Test Clips
    Micro Test Clips
  9. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Holy cow! Will you please STOP replying to your threads with lists??? It's so annoying!
    Looking stuff up is fine, but save it for a summary or something. :rolleyes:
  10. relicmarks
    Oct 13, 2006
    355
    sorry i didn't know they made SMD test probes , these are the only ones i found do you guys know any more or what do you guys use
  11. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Test clips for ICs have been made since ICs have been around.
    I have some that are probably older than you are. ;)
    Look, you really can't continue posting in the manner that you have been; simply posting more questions and lists on top of questions.
    We're here to help, but within reason. You're not being reasonable; it's like you are a black hole to suck information in with no acknowledgement or discourse back.
    There is very little interaction on your threads.
    This is just not acceptable.
    Change your ways, or find someplace else to hang out.
  12. relicmarks
    Oct 13, 2006
    355
    i know they make Test clips for ICs
    but i never seen SMD or fine pitch IC test clips
  13. JoeJester
    Apr 26, 2005
    3,393
    1,211
    Sgt,
    The best way to lower your blood pressure is to stop responding to those posters that raise it.
    After a 12 years of postings, that works the best.
    It works for this ol' CPO.
  14. Audioguru
    Dec 20, 2007
    9,411
    896
    His posts on other websites (aka Walters) get the same reaction.
    I think he was banned from another website or two.
