Hello:
Im making a shift light using a comparator, multivibrator, and displayer. My question is on the breadboard, can i have the topmost rail be my 12V supply and the rail below that be my 5V supply? i checked with my dmm to make sure they are independent but the dmm made a beeping sound. personally i like my power rails to be the top 2 and use the bottom 2 for grounds. is this okay?
also, i have some 2x2.5mm clear leds and i was wondering if the line represents the cathode or anode?
thank you
tron
thank you
tron
