BMorse -- thanks for your quick response. Have you tried both the Digikey and Mouser ones, and are they both good quality?
Regards
pilko
I've done the same, but 26 ga tends to slip out of the holes too easily. I find the "official" jumpers give better grab in the long run.Neat is nice, but many assorted lengths of 26 ga telco wire have worked for me for 30 years. There is enough stray capacitance from a breadboard that loops above the surface make no difference.
Yeah, but it is a lot easier to trace problems if it is neat. A rule of thumb I have found to be true over the decades is the neater the project, the more likely it is to work the first time. This also applies to breadboards.
26 Gauge works OK, but it is also better if the wire is stiffer than normal. I've used 22 Gauge on the older breadboard. Currently I'm using 24 gauge off of roles that was meant for the use.
Yep, on the shelf at several electronics outlets. Too expensive for my tastes. Instead, I bought a cheap kitting box from Walmart ($2) and cut and bend my own, then store them when I'm through. I have 6 or so breadboards, and lately have had all of them in use for various projects. I don't use SPICE, I use try and see.Has anyone tried these ?
Making it neat usually means you have checked and double checked. I think we're going to have to disagree on this one.
Oh that is so uncool. Only n00bs need to debug a circuit. My circuits work always as expected the first time. Current limiting and fuses is for wieners(I hate that when that happens, it just adds to the problem when trying to debug a circuit!!)
I agree! Plus less chance of yanking out a loop when making changes to the design.... (I hate that when that happens, it just adds to the problem when trying to debug a circuit!!)
My .02
But if breadboarding uControllers you are going to need loops... and conditionals, and of course switch.
by Duane Benson
by Jake Hertz
by Jake Hertz
by Aaron Carman
