Branch Current Method
Discussion in 'Homework Help' started by Bill Allman, Apr 20, 2009.
  1. Bill Allman
    Apr 20, 2009
    Doing a quick refresher on Branch current method. I'm fine until I reach the final part of the lesson and he figures the current values from these final equations.
    -1I1 + 1I2 - 1I3 = 0 KCL
    4I1 + 2I2 + 0I3 = 28 KVL
    0I1 - 2I2 - 1I3 = -7 KVL
    I1 = 5A
    I2 = 4A
    I3 = -1A
    Could someone show the algebraic equation that shows how we get 5 amps, 4 amps, and -1 amp from these equations above.
  2. guitarguy12387
    Apr 10, 2008
    359
    12
    You have to simultaneously solve each equation. I usually do it by the substitution method. Solving one equation in terms of the other variables and then back substitute. Or if you have a TI-89, it can do it quick and easy.
  3. Jack Bourne
    Apr 30, 2008
    39
    I have seen some people solve it by using Matricies. I personally do not know how to do it this way so I would either use my calculator as it has a solve function on it or just use the substitution method.
    So Basically, you've got these equations 4I1 + 2I2 = 28, - 2I2 - 1I3 = -7, -1I1 + 1I2 - 1I3 = 0 . These are easy to use as you can have I2 = 14-2I1 -> into second -2(14-I1) = I3-7 so -I3= 21+2I2 -> into third and it gives you the answers.
  4. jasperthecat
    Member
    Mar 26, 2009
    20
    Another way of solving the set of equations is to use the linear programming approach This is relatively straight forward for 3 or 4 unknowns . You aim to get 2 co-efficients as zero on one line and one coefficient as zero on another.
    -1 +1 -1 = 0
    +4 +2 0 = 28
    0 -2 -1 = -7
    Multiply equation 1 by 4
    -4 +4 -4 = 0
    +4 +2 0 = 28
    0 -2 -1 = -7
    Add equation 1 to eqn 2
    0 +6 -4 = 28
    +4 +2 0 = 28
    0 -2 -1 = -7
    Multiply eqn3 by 3
    0 +6 -4 = 28
    +4 +2 0 = 28
    0 -6 -3 = -21
    Add eqn 1 & 3
    0 0 -7 = 7
    +4 +2 0 = 28
    0 -6 -3 = -21
    From eq 1 gives I3 = -1
    Substitute in eqn 3
    I2 = 4
    Substitute in 2
    4 I1 = 20
    I1 = 5
    J
  5. hgmjr
    Jan 28, 2005
    9,030
    214
    Matrix algebra is another technique for solving such a system of linear equations.
    hgmjr
