i am not sure how to figure this one out i can do the ones with 2 voltages sources ill explian the circute best i can since i dont know how to input a circut here
left line is vertiacal with 10v positve on the top end the a 5.6 k ohm resistor now the wire goes to the right and has one wire going down in the middle after the wire goine down on the top wire there is a 3.3kO resistor now the wire goes down and has a 30v power supply with the pos bieng on top then the wire goes left makeing a rectangle with the gound and the center wire going from top to bottom has a 2.2ko resistor on the top part and a 20v power supply with the negitvie on the top so the postive is on the bottom part hope thats not to confuseing
