BQ2054 Battery Charger
rfitas
Joined Jul 25, 2014
Hello!
I'm trying to implement a battery charger using TI's BQ2054. However, I'm stuck at charge pending state. I disabled temp monitoring according to the datasheet, that's why I can't figure out why I'm getting stuck there.
Also, I'm not sure about what I am supposed to do with the MOD pin.
Can someone point anything I might be doing wrong?
PS: The battery is a Turnigy 3600mAh 3Cell 11.1V.
Lestraveled
Joined May 19, 2014
1,946
First, please post a schematic. Nothing much will happen without one.
Second, the MOD pin is the control for a switch in a switching regulator that controls current to the battery being charged. If you don't know what this pin is for you really really need to post a schematic.
I have built several lead acid battery chargers using the BQ2031. It is very similar to the BQ2054.
Mark
Lestraveled
Joined May 19, 2014
1,946
rfitas
The BQ2054 is a battery charger controller and a controller for a switch mode power supply (SMPS). The SMPS handles the high current that charges the battery. The SMPS is what is missing from your circuit.
Mark
