BPSK modulator via AVR and DAC
Discussion in 'The Projects Forum' started by eric_s88, Apr 4, 2012.
  1. eric_s88
    Apr 20, 2011
    157
    Hi everyone!
    I have to design a BPSK modulator via AVR and DAC..
    the function must be like this : when PB0 is at "Low" level we must have a Sinusoidal wave with 0 degree phase at the output of DAC
    when PB0 is at "High" level we must have a Sinusoidal wave with 180 degree phase at the output of DAC..
    I've decided to use DAC0800 as my digital to analog converter. and I know how to use an avr chip and program it in C language.
    but I want to know the algorithm and how to use DAC0800..
    the datasheet of DAC0800
    http://eedept.ncue.edu.tw/study/labs/semilab/Experiment_Data/Experiment_data_sheet/DAC0800.pdf
    can anybody help ?
  2. eric_s88
    Apr 20, 2011
    157
    there isn't any idea??? :(
  3. eric_s88
    Apr 20, 2011
    157
  4. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
    You are saying that you want to switch the phase of a signal with an output of the AVR.
    How do you want to generate the signal itself?
    Bertus
  5. eric_s88
    Apr 20, 2011
    157
    Hello
    I want to generate the signal via DAC0800 . look at the device datasheet at the first post.. I cant understand it :(
