BP9831A data sheet
Discussion in 'General Electronics Chat' started by hp1729, Aug 18, 2016.
Thread Status:
Not open for further replies.
  1. hp1729
    Nov 23, 2015
    2,086
    232
    Can anybody find one in English? From what I can find it looks like VCC should be around 16 V. Can I get a confirmation from somebody?
  2. debe
    Sep 21, 2010
    955
    185
    If you look at the circuit I posted betwean pins 3&4 theres a capacitor 1.5uf & a resistor fed through droping resistors from the main supply.
  3. hp1729
    Nov 23, 2015
    2,086
    232
    It looks to me that the board is more designed for110 V. 240 V would put more stress on the internal Zener. Maybe 51K would be better than 150K for 240 v operation? But then it wouldn't work so well at 85 V :)
    One board for 85 V to 240 V? Seems to have a shorter life at 240 V. :)
    Wow, all the LEDs are in series? Current limiting is set to about 120 mA, 240 mA maximum.
    Not a bad little chip. A bigger case with a bit of heat sink might be a good idea.
  4. debe
    Sep 21, 2010
    955
    185
    When it was working I managed to measure the voltage across the LEDs at 85V dc, & the current at 100ma. Just checked the Vcc voltage its 12V dc.
  5. hp1729
    Nov 23, 2015
    2,086
    232
    Thanks for the checks. Good work on the schematic.
  6. DickCappels
    Aug 21, 2008
    2,755
    665
    After some discussion, this thread is in conflict with the User Agreement to which we are all a party. It is not closed.
    Restricted topics. The following topics are regularly raised however are considered "off-topic" at all times and will result in Your thread being closed without question:
    • Any kind of over-unity devices and systems
    • Devices designed to electrocute or shock another person
    • LEDs to mains
    • Phone jammers
    • Rail guns and high-energy projectile devices
    • Transformer-less power supplies
    http://www.allaboutcircuits.com/user-agreement/
    A not to those who participated in this discussion, I hope that the next time you find this sort of issue, you report it.
Thread Status:
