Bose CineMate DB9 connector pinout?
Discussion in 'Technical Repair' started by wayneh, Sep 23, 2016.
  1. wayneh
    Thread Starter Expert
    Sep 9, 2010
    12,362
    3,220
    A friend found a Bose subwoofer at a garage sale. No cables, just a black box (literally). Anyone have experience with these, or know where to find the pinout?
    It has DB9 connectors on the back and those seem like those are signal in and out to the other speakers. I have plenty of old DB9 cables I can hack but I can't find anything about the pinout of those connectors. I assume the signals are all analog?
    I'm guessing at least one conductor switches the subwoofer on, since there is no switch on it. Then there should be signal common and at least two conductors for stereo. Not sure what else.
  2. wayneh
    Sep 9, 2010
    12,362
    3,220
    I took the back off the subwoofer and pulled the PCB with the connectors on it. The one on the left in the picture is the input. So far this isn't telling me much. See anything that helps?
  3. wayneh
    Sep 9, 2010
    12,362
    3,220
    Here are additional views.
  4. RichardO
    May 4, 2013
    1,334
    429
    Sorry but I can't help much but I wonder if it is a variation on this: Bose_15 pin.jpg
    p.s. I really like those spark arresters. I have never seen that before.
  5. nsaspook
    Aug 27, 2009
    3,006
    2,348
    Tell you friend to make it into a plant pot as that's the best use of a Bose speaker system.
    wayneh likes this.
  6. wayneh
    Sep 9, 2010
    12,362
    3,220
  7. RichardO
    May 4, 2013
    1,334
    429
    The pointy things on a number of the pins of the left hand connector in your first picture. Just a guess on my part.
  8. wayneh
    Sep 9, 2010
    12,362
    3,220
    Oh those "teeth"! I wondered about those. Without a closeup, I thought they bridged across to ground but they do not.
  9. Kermit2
    Feb 5, 2010
    3,838
    961
    I don't think that model had surround outputs. Just a left and right.
    For audio input like from a stereo jack. Connect tip, ring and sleeve to pins 2,3 and 5.
    You will not be able to use a remote to turn on and off, mute, or adjust volume without the input adapter module.
    Also know that bose uses a special audio "envelope" type power output and the speakers have a unique coil and suspension. Regular speakers used in the left and right channel will sound less than ideal and if not robust enough may even burn out.
  10. Kermit2
    Feb 5, 2010
    3,838
    961
    Not sure anymore what pin was used for remote on off. You really need that adapter unit to make it worthwhile.
  11. wayneh
    Sep 9, 2010
    12,362
    3,220
    Yeah, that's the conclusion I've come to after wasting some time on this thing. The "interface modules" sell for ~$90 on e-bay while the subwoofer (and amp) like my friend grabbed sell for half that. I think I'll advise my friend to sell the speaker on e-bay as-is for $20 and be done with it. It'd be worth more if I could determine that it works, but I don't know how to do that.
  12. nsaspook
    Aug 27, 2009
    3,006
    2,348
    How to repair your Bose woofer.
    wayneh likes this.
