Bootstrap Capacitor Calculation Issue
Discussion in 'General Electronics Chat' started by DumbDummy77, Feb 1, 2010.
  1. DumbDummy77
    Jan 21, 2010
    43
    Hi
    I am currently learning how to calculate the bootstrap capacitor for IR2110 Application. So far I have identified every parameters apart from one:
    Qgate 27E-06
    Frequency 21600
    Icbs(leak) 0
    Qls 5.00E-09
    Vcc 14
    Vf 0.78
    Vls 4.5
    Iqbs(max) 230E-06
    Vmin ??
    I use the forumla from Application Note AN-978 on page 6. At the moment I am not certain on how to obtain Vmin, I use a half bridge configuration and the voltage is about 100V and the IGBT is IRG4BC20UD.
    Please explain me how to obtain Vmin?
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Vmin = the minimum voltage between Vb and Vs.
    Vb = the high side of Cboot.
    Vs = the junction of the high side MOSFET source and the low side MOSFET drain; the load connection point.
  3. DumbDummy77
    Jan 21, 2010
    43
    Can you please give me an example in number?
    Regards
    MM
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    It depends on the MOSFET you're using.
    If it's a standard level MOSFET, you'd want Vmin to be 10v.
    If it's a logic level MOSFET, you'd want Vmin to be 5v.
    If it's a very low threshold MOSFET, you could use a lower number for Vmin.
    Cboot is what supplies the current to charge the MOSFET gate to turn it on. In order for a standard level MOSFET to be considered fully turned on, you need to get the Vgs (gate relative to the source voltage) up to 10v.
  5. DumbDummy77
    Jan 21, 2010
    43
    Right I get the picture, for my application, I use IGBT such as RG4BC20UD at the moment. According to the datasheet, the Vge is +/-20V so that mean I apply 20V in Vmin. Is it correct?
    I am struggling to understand it, to be honest with you. Can't you give me a design example? Hopefully i grasp the idea quickly
    Regards
    MM
  6. S_lannan
    Jun 20, 2007
    247
    Nothing too complicated. Just make that voltage a suitable voltage to turn on the IGBT.
    Try 15v it's what most IGBT gate drive circuits i've seen use.
    It's somewhere inbetween VGE(th), which is the voltage where the device beings to conduct, and VGE(max), the maximum voltage you can put on the gate.
  7. DumbDummy77
    Jan 21, 2010
    43
    What about MOSFET?
  8. DumbDummy77
    Jan 21, 2010
    43
    Vmin is the difference between Vb and Vs. Hence since Vb is connected to Vcc which make 12V (Vcc = 12V). I am not sure about Vs to be honest. If I am mistaken about this, please correct me asap
  9. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You need to look at the Vce(on) specification in the datasheet.
    There you will find Vge=voltage - for that particular IGBT, it's 15v.
    If the design is simply handed to you, how much would you learn in the process?
    You say you already have all the other numbers - plug them into the formula, and you'll have your result.
  10. DumbDummy77
    Jan 21, 2010
    43
    Thank you SgtWookie and I have another question to ask you do I need to connect correct resistor from the IR2110 to the gate of IGBT. If yes, what forumla should I use?
  11. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Go back to that same Application Note, and start reading on page 9.
    Note the reference to DT97-3 on page 11.
  12. legaspito
    Nov 21, 2011
    i believe you should use a resistance value that does not make your voltage drops under the specified Vg you know what i'm saying
  13. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    This topic has been asleep for 21 months, and the original poster has not returned since the end of May. It is not likely that they still require help on this.
    Please view the last reply date of the original poster before replying to a thread.
