Bootloader is good or bad
Discussion in 'Embedded Systems and Microcontrollers' started by embpic, Apr 8, 2014.
  1. embpic
    May 29, 2013
    187
    i have doubt that wheather bootloader is good or bad?
    if i am using any kinda of bootloader that is serial or usb so there is need to remap the vector address.
    so i am confuse that whether it good for any project??
    and does remapping make any affect on firmware?
    which bootloader is good??
  2. t06afre
    May 11, 2009
    5,939
    1,222
    Boot loader is a poor mans programmer. If you have a PIC programmer (assuming you are using PIC due to your XC8 thread) stay with that. At least until you learn more about programming
  3. ErnieM
    Apr 24, 2011
    7,436
    1,625
    A bootloader is an inexpensive way to program a micro, period. For hobby use it can replace the need for a programmer (as long as you can work with one chip that never burns out or gets erased). For professional use it can get a firmware update into your product without costly returns.
    "Good" is too subjective a term to comment upon.
    Any bootloader that works with your micro is "suitable."
  4. embpic
    May 29, 2013
    187
    thank you for your valueable feedback but as for bootloader vector address need to be re-map then will it affect on firmware flow. means while running firmware will it affect.
  5. JohnInTX
    Jun 26, 2012
    2,394
    1,051
    AN1310 describes how to implement bootloaders on PIC16 and PIC18.
    EDIT: MikroC has bootloader support on the library level derived from AN732. Serial and USB are supported. If you download the free version of the compiler, you can consult the Project Manager and user's manual to see how they did it.
    I haven't used them - yet.
  6. THE_RB
    Feb 11, 2008
    5,435
    1,305
    I used the MikroC bootloader on their SmartGLCD product.
    It worked good enough, but was quite slow compared to the proper PIC programmer, and the bootloader had no benefits (to me) so I just switched to using a proper programmer.
    I think the only benefit was for people who did not own a programmer (so it was better than nothing).
  7. ErnieM
    Apr 24, 2011
    7,436
    1,625
    Bootloaders typically run for a few instructions as the device starts; that is when they check for the "update required" switch. If no update they toss execution to the main program and don't run again.
    The main program does need some special handling as to where it resides, usually a custom linker script is all you need.
    The exact process is highly device and compiler specific.
  8. embpic
    May 29, 2013
    187
    thank you all of you . bcoz i just looking for solution like nxp's 8051 get programmed via simple flash magic and serial cable instead of middle adds ons.
  9. fernan82
    Apr 19, 2014
    26
    9
    If you use it as an alternative to a programmer during development then it's just a poor mans programmer as other pointed out. If your application needs to be updated on the field by non-tech users then it is the only way to go. The only difference it makes on the firware is the location where it is stored in memory.
  10. Art
    Distinguished Member
    Sep 10, 2007
    797
    61
    If you're talking about it messing with your program because it resides at the
    chip's reset vector then I think it's unlikely ever a problem depending where your interrupt vector is,
    and how that's handled if the bootloader is consuming that memory as well.
    The only thing I can think of jumping to reset vector is actual hardware reset or reset by watchdog,
    and both of those instances, timing should not be critical.
    I imagine a bootloader would jump out to some other memory to avoid
    consuming the interrupt location like any other program does.
    So I think it just boils down to the bootloader consuming a little of the chip's
    memory to store the serial routines it uses to write itself.
  11. THE_RB
    Feb 11, 2008
    5,435
    1,305
    It doesn't need to be at the reset vector.
    All that is needed is that the executing firmware at some time provides an option of running the bootloader or not.
    The only real cost is the bootloader uses up some ROM, and probably a whole chunk because internal ROM-writes are usually chunk based.
    embpic likes this.
