Boot Manager - I need to boot from 2 different SATA drives
Discussion in 'Computing and Networks' started by maxpower097, Oct 8, 2010.
  1. maxpower097
    Feb 20, 2009
    795
    388
    Ok so I have 3 SATA harddrives. 1. 220GB, 2. 80Gb, 3. 1.5TB. I have Windows XP installed on the 220GB drive and I want to install Unbutu linux on the 80GB drive. Is there a freeware boot manager where I can select to boot from different harddrives? My bios could do it but I'ld have to switch OS's by bios every time. It won't recognize 2 HD's for booting, just 1.
  2. shteii01
    Feb 19, 2010
    3,500
    511
  3. stellarpower
    Member
    Feb 19, 2009
    28
    GAG is good if you're not doing anything complex.
  4. tom66
    May 9, 2009
    2,613
    214
    When you install Ubuntu it will automatically install a bootloader on your master drive allowing you to select between Ubuntu and Windows. From experience. Never done it across multiple drives, but I have heard of that being done.
  5. maxpower097
    Feb 20, 2009
    795
    388
    I'm wondering if Unbutu formats the drive as a primary OS drive if it will show up under boot options in bios?
  6. maxpower097
    Feb 20, 2009
    795
    388
    double post..
  7. shteii01
    Feb 19, 2010
    3,500
    511
    What does motherboard documentation say on the subject?
