Sir, you are right that I need a discrete voltage step-up circuit.Many ICs are not available in The Philippines.
So he must make a discrete voltage stepup circuit and battery charger like we did 20 or 30 years ago.
A pleasant day to y0u sirHello,
Did you see this post on a philipinian forum?
http://www.electronicslab.ph/forum/index.php/topic,2665.0.html
It is about a boost converter using transistors.
Greetings,
Bertus
I was also going to suggest that he look at www.electronicslab.ph .
I hope he posts a video showing his Lithium batteries catching on fire.
Hello juan,
There are small dots near the transformet show the start of the windings.
I enlarged the shematic with comments.
Greetings,
Bertus
Greetings,The voltage stepup circuit will have an output voltage of 5.8V. The absolute maximum charging voltage for a Lithium-Ion battery cell is only 4.2V. Nothing will limit the current.
When the battery becomes over-charged by voltage or current then it will catch on fire.
0k charger IC is more advisable to recharge battery. But based on your knowledge how can this ckt. can automatically adjust its 0pt current depending to its load? Thank you.We use a battery charger IC. Maybe somebody can remember what we did 20 or 30 years ago. You are in a time warp.
