Boost or cuk convertor
Discussion in 'The Projects Forum' started by naumandar, Jan 19, 2009.
  1. naumandar
    Jan 19, 2009
    8
    Hey i want to design the Dc/Dc Convertor from 12V to 19.5V with 3.5Amp, i hav studied about SMPS(Swithing mode power supplies) and found Boost convertor and Cuk convertor, will u ppl help me and giude me that how will i gain the 3.5 amp current, which ic is useful...
    Thank u So much in advance
  2. mik3
    Feb 4, 2008
    4,846
    63
  3. naumandar
    Jan 19, 2009
    8
    Thank u so much
  4. mik3
    Feb 4, 2008
    4,846
    63
    I have never used one of these chips and didn't read the datasheet, however, I believe that you can increase the output current by using a more powerful MOS.
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Go to: http://www.national.com
    On the upper right, enter your parameters: 10 to 15 volts input, 19.5 volts output, 3.5 amps output. Start the design. Use the Flash-based webbench.
    The LM3478 with associated components can give you a boost converter better than 90% efficient.
