Boost converter turn-off time
Discussion in 'General Electronics Chat' started by anhnha, Mar 18, 2016.
  1. anhnha
    Thread Starter Active Member
    Apr 19, 2012
    776
    48
    For the boost converter below operating in DCM mode, the voltage conversion ratio is calculated as follows:
    M = V/Vg = 1 + D1/D2
    where
    V, Vg are output and input voltage respectively.
    From the formula, it is clear that the conversion ratio doesn't depend on D3. So, is there any requirement for D3 here?
  2. ronv
    Nov 12, 2008
    3,393
    1,452
    Just that the lower the voltage drop the more efficient the conversion.
    And of course the voltage and current ratings must be high enough.
  3. dl324
    Distinguished Member
    Mar 30, 2015
    3,376
    651
    D3 is primarily determined by the load.
  4. anhnha
    Apr 19, 2012
    776
    48
    Thanks.
    How does it depend on load current?
  5. dl324
    Mar 30, 2015
    3,376
    651
    When the voltage at the cap drops below the target voltage, the switch needs to turn on. A higher load will discharge the cap faster, making it necessary for the switch duty cycle to be higher.
  6. anhnha
    Apr 19, 2012
    776
    48
    Can I reduce switching frequency instead of increase duty cycle? I think it is the same here.
