Boost converter transfer function with non-ideal components
Discussion in 'Homework Help' started by J_Rod, Mar 1, 2016.
  1. J_Rod
    Nov 4, 2014
    109
    6
    Hi, I am stuck trying the derivation for a boost converter transfer function in continuous conduction, open-loop operation mode to find Vout/Vin with non-ideal components, that is, a Rsw, the MOSFET switch on-state resistance, ESR, an equivalent series resistance with the capacitor, RD, the on-state resistance of the diode, and RL, the inductor's resistance.
    When the switch is ON:
     L \frac{di_L}{dt} = V_{in} -i_L (R_L +R_{DS,ON})
     C \frac{dV_C}{dt} = \frac{-V_{out}}{R + ESR}
     C \frac{dV_C}{dt} = \frac{V_C - V_{out}}{ESR}
    When the switch is off:
     L \frac{di_L}{dt} = V_{in} -V_{out} -i_L(R_L + R_D)
     C \frac{dV_C}{dt} = i_L -\frac{V_{out}}{R +ESR}
     V_C = V_{out} -i_CESR
    Then
     \Delta i_{Lon} + \Delta i_{Loff} = 0
    But to get  \Delta i_L terms I would have to integrate the equations with the inductor voltage, which both contain a term with  i_L . How can that be done? Thanks.
  2. wayneh
    Sep 9, 2010
    12,391
    3,246
    Had diffy Q yet? I believe that's a first order differential equation. I'm pretty rusty on the terminology. It's been a long time but I believe almost any text on the subject will cover the solution.
  3. J_Rod
    Nov 4, 2014
    109
    6
    That's how to solve for  i_L , but I want to find the expression for  \Delta i_{Lon} to add to the expression for  \Delta i_{Loff} to sum to 0, and then rearrange to find  \frac {V_{out}}{V_{in}} . Would it be incorrect to set  i_L = I_L , the average value, on the right side of the equations, if I assume a small ripple?
  4. wayneh
    Sep 9, 2010
    12,391
    3,246
    Well if you have i as a function of time, can't you integrate to get ∆i ? (I'm just hoping that asking questions helps you see a solution. I haven't worked this out.)
  5. anhnha
    Apr 19, 2012
    776
    48
    There are some principles you should use here to solve for the result:
    1. Inductor volt-second balance
    2. Capacitor charge balance
    3. Small ripple approximation
    Refer to this for detail.
    With small ripple approximation, you can assume that Vout and iL are constant (and let's call it IL).
    With #1 and #2, you have set of two equations and you can now solve for Vout and IL.
    With small approximation, iL in the right hand side can be considered as a constant.
    However, if you want an exact calculation, then I think it is much easier to use Laplace transform.
