Boost converter regulated output (fixed)
Papabravo
Joined Feb 24, 2006
21,228
Breadboarding a switching regulator is almost always a mistake. The capacitor cannot supply the current, or inductor cannot handle the current demand of a cold filament, or the source cannot supply at least twice the instantaneous current demand, that is most likely why the voltage drops.
Your output power is 1.3 watts, so I estimate your input power requirement as 1.62 watts. At 9V this is .18 Amperes from the batteries. Are they capable of supplying that much power?
Ylli
Joined Nov 13, 2015
1,088
Light bulb is 2.5 volt/0.35A? And you are connecting this to what is nominally a 14 volt output?
The bulb is going to try to draw much more than 350 mA. And your input current is going to be almost 3x the current draw of the bulb. The AA batteries may not be able to supply sufficient current.
When the output drops to 3.5 volts, what does the input voltage measure?
BobTPH
Joined Jun 5, 2013
9,003
Measure it's resistance.
You also must know the max current for the inductor. If exceeded it will saturate and not perform correctly.
Bob
