Boost converter problem
Discussion in 'General Electronics Chat' started by Arjuna, Aug 31, 2012.
  1. Arjuna
    Aug 31, 2012
    Hello everybody!
    I have a problem with boost converter. I can get max 90V from 20V source and then all circuit colapses and output mosfet get shorted. Output voltage changes in dependence on choke but i could never get 220V from 20V source.
    Also, audible noise form choke is present while adjusting output voltage,
    Do you have idea what's going on here?
  2. absf
    Dec 29, 2010
    1,493
    374
    Without a circuit diagram, I have no idea what are you talking about. From your description, are you using low frequency oscillation for your converter, like <1 KHz ?
    BTW, what is your load?
    Allen
  3. praondevou
    Jul 9, 2011
    2,936
    489
    Measure the inductor current. See if it's saturating when increasing the PWM pulse width. If that's the case increase inductance or frequency.
    And yes, we need a schematic.
