Boost converter load current
Discussion in 'General Electronics Chat' started by anhnha, Feb 16, 2016.
  1. anhnha
    Thread Starter Active Member
    Apr 19, 2012
    776
    48
    Here is a boost converter operating in discontinuous conduction mode (DCM).
    From this page:
    The load current Io is equal to the average diode current (ID).
    Can anybody explain it?
  2. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,691
    1,297
    100% of the load current comes through the diode. That current comes through in pulses, not continuously. Those pulses are averaged (integrated) by the output capacitor C. The load and the diode form a series circuit, so the average power in the load must come through the diode.
    ak
  3. Jony130
    Feb 17, 2009
    3,990
    1,115
    But what you do not understand?. When the switch is closed Id = 0A and the cap provide all the current. But when switch is open the coil will provide Io and in the same time the coil will charge the cap.
  4. anhnha
    Apr 19, 2012
    776
    48
    Thanks but why load and diode are in series?
    The load current will be affected by the capacitor and diode current. Why capacitor doesn't have influence in load current?
  5. ErnieM
    Apr 24, 2011
    7,436
    1,626
    Because the net current into and out of the cap is zero.
    Any current sourced by the cap to load must come from thru the inductor, and later be returned thru the diode.
    (nitpickers may note I am actually referring to charge not strictly current)
  6. AnalogKid
    Aug 1, 2013
    4,691
    1,297
    The capacitor does not pass any current at DC, so it has no affect on the long-term average output current. It affects the shape of the load current, but not its average value. The diode and the load are in series because that is what is on your schematic. If you are asking why they are that way on the schematic, it is because of Faraday's Law:
    https://en.wikipedia.org/wiki/Faraday's_law_of_induction
    ALL switching power supplies function by turning the input DC into some form of AC so it can use a transformer or inductor to modify the energy, then rectifying and filtering the output to turn the power stream back into DC.
    ak
  7. crutschow
    Mar 14, 2008
    13,496
    3,373
    When S1 is closed Vi causes the current to increase in L, storing energy equal to 1/2 LI^2.
    At this point the diode keeps the voltage the capacitor from being discharged to ground
    Also the load is being supplied current from the charge stored on the capacitor.
    When S1 opens, the stored energy in L's inductance keeps the current moving through D to recharge the capacitor and provide load current.
    This continues until all the inductor energy is transferred to the capacitor.
    The charging and discharging of the capacitor creates a ripple voltage on the output DC as determined by the C value, the load current, the input voltage, the inductor size, and the switching frequency.
  8. anhnha
    Apr 19, 2012
    776
    48
    Thanks for these responses.
    I think I've got it now. The said load current is the average not the instantaneous.
