boost converter inductor value
thatoneguy
Joined Feb 19, 2009
6,359
The output ripple is usually a function of the output filter, typically a capacitor. Sometimes useless information is added to a question, sometimes it may appear useless, but some part of it is actually required.
notoriusjt2
Joined Feb 4, 2010
209
here is another similar one
Vs=5V
Vo=15V
R=75ohms
f=100kHz
T=10uS
D=.667
the book gives me this equation for max inductor current
Imax=(Vs/(((1-D)^2)R)+((VsDT)/(2L))
solving for Imax gives me 11.9uH
is this the correct equation?
thatoneguy
Joined Feb 19, 2009
6,359
Vs=5V
Vo=15V
R=75ohms
f=100kHz
T=10uS
D=.667
Click My Sigline. ;)
\(Imax={V_s\over {((1-D)^2 \cdot R) + \frac{V_s \cdot D \cdot T} {2 \cdot L}}\)
1st, Does the equation above match your book?
2nd: How did you rearrange it to solve for L?
thatoneguy
Joined Feb 19, 2009
6,359
Ok, I'll work it out here.
Vs=5V
Vo=15V
R=75ohms
f=100kHz
T=10uS
D=.667
\(I_{max}={\frac{V_s}{(1-D)^2 \cdot R}+{\frac{V_s \cdot D \cdot T}{2 \cdot L}}
2={\frac{5}{(1-0.667)^2 \cdot 75}+{\frac{5 \cdot 0.667 \cdot 10\times 10^{-6}}{2 \cdot L}}
2=601.2\times 10^{-3} + {\frac{33.35\times 10^{-6}}{2 \cdot L}
1.3988=\frac{33.35 \times 10^{-6}}{2 \cdot L}
2.7976 \cdot L=33.35 \times 10^{-6}
L = 11.921 \times10^{-6}
L = 11.921 μH
So, we either both did it wrong in similar ways, or it isn't the correct formula they want you to use in this instance. :D
notoriusjt2
Joined Feb 4, 2010
209
the professor submitted the same question with new answers and 10uH was on there. So I went with that and by golly I got it right
