Boost Buck Converter Using 2N7000
YY0821
Joined Oct 22, 2016
Hi guys,
I wanted to build a boost buck converter using 2N7000.
The converter is only working with low voltage, like 5V.
Is 2N7000 suitable for this application?
Please give me some suggestion :)
Alec_t
Joined Sep 17, 2013
14,335
Welcome to AAC!
The 2N7000 can't handle much current. What output voltage and current are you hoping to get from the converter?
ci139
Joined Jul 11, 2016
1,898
500mA for 2N7000 → https://www.fairchildsemi.com/datasheets/2N/2N7000.pdf
http://www.simonbramble.co.uk/dc_dc...nverter/sepic_buck_boost_converter_design.htm
http://www.ti.com/product/LM5118/datasheet/detailed_description
non of the parts alone makes your design
but setting limits to- / ranging- your design
may define the conversion frequency that sets requirements for inductors transistors mosfets diodes PCB design e.c.
from scratch it's always possible to make about 2kHz to 8kHz converter with the efficiency of about 60%
if you wan't to get a lot of output current/power your voltage regulation suffers , your efficiency may suffer at low voltage supplies . . .
(as a rule in web forums) not knowing your exact design parameters (web forum rule ends) it's difficult to tell
YY0821
Joined Oct 22, 2016
Welcome to AAC!
My application required only 0.2A to 0.5A and 3 to 8 voltage. I have checked the data sheet of 2N7000, the drain current is around 240mA. Therefore, I am not so sure whether 2n7000 can be used.
YY0821
Joined Oct 22, 2016
Sorry for left out the design parameter,
I have done some simulation about the converter. I have an input of 5V to drive a 12 V DC motor so that it can have different rpm. The current will be ranging from 0.2 to 0.5A.
The circuit is attached, from the simulation, the result seems to be desired. However, I am currently having only 2n7000 so not sure whether it can do the job. The load is modelled as a 14 ohms resistor.
DickCappels
Joined Aug 21, 2008
10,187
No, it won't if you need 500 ma at 8v out, you would operating it beyond its current rating. To obtain reliable operation you need to either change your specification or change your transistor.
8 V x 500 ma = 4 Watts
4 Watts / 5 V = 800 ma
The above considers 100% efficiency and average current on the input but the peak current will be much higher.
