Not quite. Power out will always be less than power in. They will be equal only in an ideal universe, which this one unfortunately is not. I like to use 80% as a "rule of thumb" efficiency for a boost SMPS.boost converter. It is possible. Just remember, power in equals power out.
Why don't you explain "in detail" exactly what you are trying to do with this 48V signal and what are the details on this 12V source?Hi friends
Source is 12v, 1.2mA
And output 48v and amper not important
Thanks All
Then you will only get maybe 250 uA of current from the 48V side. You could just use a 555 free running (driving a 2N3904) with a coil/diode and a zener diode to clamp it at 48V.Hi friends
Thanks All
HiHello,
I think this thread is the sucessor of his previous thread:
simply convert 12v dc to 300v
It looks like he is going lower and lower on the output voltage.
Bertus
Hi and thanks for answerThen you will only get maybe 250 uA of current from the 48V side. You could just use a 555 free running (driving a 2N3904) with a coil/diode and a zener diode to clamp it at 48V.
Here is the basic circuit used in a circuit to boost 9V to about 39V (three 13V zener diodes in series clamp the voltage)..Hi and thanks for answer
This is exactly I want
You can give me a circuit
thanksInstead of a 555 timer IC and a transistor, you can use two transistors like the schematic on this page;
http://www.romanblack.com/smps/conv.htm
However you will need to change a few resistor values to make it run from 12v 1.2mA, and of course the output zener diode needs to be changed to a 48v type.
thanksHere is the basic circuit used in a circuit to boost 9V to about 39V (three 13V zener diodes in series clamp the voltage)..
PWR is input, output is at the top of the three 13V zener diodes.thanks
pwr=input voltage??
where is the output voltage
Then Proteus has failed or (more likely) YOU have failed to simulate it properly.thanks
i simulation this circuit if proteus but not working
thanksThen Proteus has failed or (more likely) YOU have failed to simulate it properly.
The real circuit works well and has been built by many people.
