Boolean simplification....kind of stuck on a certain form of expression
Discussion in 'Homework Help' started by RyanKim, Nov 17, 2011.
  1. RyanKim
    Sep 18, 2011
    37
    Hi guys I was wondering if anyone could take a look at 2 expressions I have that I can't seem to simplify. Im basically one step away from the answer at both junctures but I can't logically apply a law that I know how to use to get the answer.
    The first equation that I've pretty much solved has boiled down to this:
    1.) A!B! + B!C + A! + B! + C! (Where ! means not. E.g A! = A not)
    Final answer suppose to be A! + B! + C!
    and secondly
    2.) Q! + R! + S! + R!S + QR!R!
    Final Answer suppose to be Q! + R! + S!
    I cant seem to figure out what to do next. Im not aware of any law that can be applied here...though I do notice in both expressions B! and R! may have something to do with it respectively?
    Thanks!
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    how about ...
    A!(B! + 1) + B!(C + 1) + C!
    what's next?
  3. t_n_k
    Mar 6, 2009
    5,448
    783
    I don't think your second question partial solution is correct - if that's the given solution. Can you post the original question?
  4. justtrying
    Mar 9, 2011
    329
    398
    for the second part try factoring out R!
    Q!+S!+R!(1+S+QR!) =
    is there any law you can apply now? think of 1+X = X
    p.s. even before grouping, you can simplify R!R! - recall XX = X
  5. RyanKim
    Sep 18, 2011
    37
    Ahh thanks T_N_K I think I got the first bit...(X + 1) = 1. For the second part perhaps I should have added brackets but that was the given solution by my prof.
    Q! + R! + S! + (R!S + QR!R!)
    So I guess R!R! = R! therefore (R!S + QR!) = R! ? Then Q! + R! + S! + (R!) = Q! + R! + S! Since ( X + X = X)?
    f = ( (QRS) (R + ( S + (QR!) )! )!
  6. t_n_k
    Mar 6, 2009
    5,448
    783
    A computer generated minimization gives me the solution
    X = not Q or not R or not S or not RS;
    which doesn't match up with the solution you have.
  7. RyanKim
    Sep 18, 2011
    37
    Really now? Hmm thats odd...Well if ud like to see my profs solutions for them Ill upload a PDF of it.
  8. justtrying
    Mar 9, 2011
    329
    398
    you can also do this:
    !(QRS(R+!(S+Q(!R))) = !(QRS(R+!S(!Q+R)) = !(QRS(R+!S!Q+!SR) = !(QRS)
    if you are wondering about how I got the final answer, check out basic multiplication rules ;)
  9. justtrying
    Mar 9, 2011
    329
    398
    not quite...
    (R!S + QR!) cannot equal R! but Q!+R!+S!+R!S+QR! is valid. Then what happens if you factor out R! (see earlier post)
  10. t_n_k
    Mar 6, 2009
    5,448
    783
    My mistake. Finger trouble - I didn't enter the equation correctly. The application now spits out your given answer.
