Boolean Simplicifation -Sorry
Discussion in 'Homework Help' started by Iamthewalrus, Mar 14, 2007.
  1. Iamthewalrus
    Mar 14, 2007
    Hey guys.
    I'm currently working on a circuit for school and i have arrived at this stage. I personally do not know where to go from this stage as there are 6 inputs and i have trouble with merely 2. Any help what so ever would be very much appreciated.
    The underlines being the nots:
    1. B.P.(D+S+F+M)
    2. D.M.(P+S+F+B) + D.B.(P+S+F+M) + D.M.B.(P+S+F)
    Thanks guys :)
  2. Papabravo
    Feb 24, 2006
    10,338
    1,850
    You need to start with DeMorgan's therorems. There are two of them. Then you need to express your formulas in the sum of products form. From this point there are a variety of techniques to minimize the expression. My favorite is the method of prime implicants.
    Good Luck
  3. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Just so you know, 1 is in its simplest form.
    I'm struggling a little with the original question. Can you explain more precisely what you are trying to do? Part 2 can be simplified in one of several ways depending on what you are trying to achieve.
    Dave
  4. Blue_turnip
    Mar 5, 2007
    8
    I don't know if you know the OP or not, therefore this is inappropriate.
    Dave
  5. recca02
    Apr 2, 2007
    1,211
    have you learned abt kernaugh map or quinn mcclusky methods.
    wiyh those methods and a multiplexer you might be able to implement
    the logic with lesser inputs or atleast with a less complicated expression.
