Boolean logic
Discussion in 'Homework Help' started by dagarve, Nov 4, 2006.
  1. dagarve
    Nov 4, 2006
    need help:
    how do I simplify this equation. AB+(-A-BC). -A & -B means not A and Not B.
    My email address is dagarve@comcast.net
  2. Papabravo
    Feb 24, 2006
    10,338
    1,850
    As written it is ambiguous. Does -BC mean "not B and C" or does it mean "not (B and C). You can either use parentheses or transform the expression to reverse Polish notation.
  3. Papabravo
    Feb 24, 2006
    10,338
    1,850
    Rewriting the expression with parentheses as AB + (-A-B)C
    This expression is already in minimal form. There are no common factors, and thus there is no simplification. Why do you think that there is?
  4. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    If I'm not mistaken, rewriting the expression with parentheses as AB + (-A-(BC)), it is also in minimal form (consider the expression using DeMorgans theorum).
    With only one of exach term I don't see how this can be simplified.
    Dave
  5. vikram_kumar
    Nov 2, 2006
    IF expression
    (1)
    AB+A'+(BC)' (use "(XY)'=X'+Y' " )
    =AB+A'+B'+C'; (use "X+X'Y=X+Y" )
    =A'+(B+B')+C'; (USE"X+X'=1")
    =A'+1+C' (USE"1+X=1")
    =1
    IF expression
    (2)AB+A'+B'C
    =AB+A'+B'C; (use "X+X'Y=X+Y" )
    =A'+B+B'C'; (use "X+X'Y=X+Y" )
    =A'+B+C' ;
  6. Papabravo
    Feb 24, 2006
    10,338
    1,850
    I think you copied the original expression incorrectly. There are only two terms, not three.
