Hello, I had to do complete the problems as outlined below this paragraph. I completed parts a-b as per the attached image, however I cannot complete part c which is 'how to use De Morgan's theorem to prove a relationship between the two Karnaugh map simplified formulas'. Can anyone see what I am doing wrong here ?
Thanks kindly for any help.
(a)
Design a circuit which has the four bits of a BCD number as its inputs and
has an output X so that:
X = 0 if inputs are a valid BCD number
X = 1 if inputs are an invalid BCD number.
(b)
Redesign the circuit of (a) so that:
X = 1 for valid BCD
X = 0 for invalid BCD.
(Note: DO NOT just invert your input (a).)
(c)
Use de Morgan’s theorem to prove that the Boolean Algebra expressions
you obtained in (a) and (b) are the inverse of each other.
(a)
(b)
X = 1 for valid BCD
(c)
