Boolean expressions
Discussion in 'Math' started by Johnie, Feb 14, 2006.
  1. Johnie
    Feb 14, 2006
    How do you simplify these four boolean expressions step by step?
    1. Y = A'B'C' + A'BC + ABC + AB'C' + AB'C
    2. Y = (B + C')(B') + (A' + B + C')'
    3. Y = (C + D)' + A'CD' + AB'C' + A'B'CD + ACD'
    4. Y = AB(C'D)' + A'BD + B'C'D'
  2. CoulombMagician
    Jan 10, 2006
    37
    What are the associative, distributive, and commutative properties of complement with respect to + and * in boolean logic? Your textbook has a table somewhere.
    You know that A+A' = 1 and A*A'=0 for both states of A, start applying these identities to those equations.
  3. ecjohnny
    Jul 16, 2005
    142
    Heres is my answer.. i might be wrong in some steps but still hope it will help you out. i got Q1,2&4. Q3 got confused by the "bar". here:
    1) Y = A'B'C' + A'BC + ABC + AB'C' + AB'C
    = A'(B'C'+BC)+ABC+AB'(C'+C)
    = A'(1)+ABC+AB'(1)
    = A'+ABC+AB'
    =A'+BC+B'
    =A'+B'+C
    2) Y = (B + C')(B') + (A' + B + C')'
    =B'B+B'C'+AB'C
    =0+B'C'+AB'C
    =B(C'+AC)
    =B(C'+A)
    =BC'+AB
    3)DUNNOE
    4) Y = AB(C'D)' + A'BD + B'C'D'
    =AB(C+D')+A'BD+B'C'D'
    =ABC+ABD'+A'BD+B'C'D'
    =ABC+B(AD'+A'D)+B'C'D'
    =ABC+B(1)+B'C'D'
    =ABC+B+B'C'D'
    =ABC+B+C'D'
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    The first simplification on this one is that
    A'CD' + ACD' = CD'
    and the second simplification is that
    ( C + D)' + CD' = D'
    So we are left with
    D' + AB'C' + A'B'CD
  5. Ebag
    Dec 14, 2008
    AB'+C how can you draw this with the least number of two-input nor gates
    If you know how email me the answer at babolar4444@yahoo.com
  6. vvkannan
    Aug 9, 2008
    138
    11
    let me try.
    just implement as usual using NOT,AND and OR gate.
    adding NOT before AND will give you NOR and NOT after OR will give you NOR.
    Giving the same input to both terminals of NOR would invert the function (i.e) would act as NOT as (x+x)' = x'.
    I think 4 NOR gates would be required in this case
