Boolean expression
Discussion in 'Homework Help' started by thisonedude, Jun 29, 2014.
  1. thisonedude
    Apr 20, 2014
    52
    Hi all.
    I was wondering if i could get some help in implementing my equations into shematics. So my bojective is to use 3-input NAND gates, 2-input NAND gates, and inverters. this design will be based on the minimum SOP equations.
    My truth table was this:
    INPUT OUTPUT
    S2 S1 S0 | X0 X1 X5 X6
    0 0 0 1 0 0 0
    0 0 1 0 0 1 0
    0 1 0 0 0 0 1
    0 1 1 0 1 0 0
    1 0 0 0 1 1 1
    1 0 1 1 1 0 1
    1 1 0 1 1 1 0
    1 1 1 1 0 1 1
    For SOP, my equations (Simplified) are:
    X0 = S2'^S1'^S0' + S2^S1 + S2^S0
    X1 = S2'^S1'^S0 + S2^S0' + S2^S1'
    X5 = S2'^S1'^S0 + S2^S1 + S2^S0'
    X6 = S2'^S1^S0 + S2^S0 + S2^S1'
    I'm having a hard time designing the schematic. So far all i have is three inputs each separately being inverted and then they combing going into a NAND gate. Can anyone help me from here?
  2. MrCarlos
    Jan 2, 2010
    400
    134
    Hello thisonedude
    Let me give you a little push.
    You have to make 3 horizontal lines naming them: S0, S1 and S2.
    Below these, 3 NOT gates, naming the other 3 lines As: S0', S1' and S2'
    Analyzes the image below to have a better idea.
  3. thisonedude
    Apr 20, 2014
    52
    That was how i originally thought about doing it. But the constraints are that we are only allowed to use 3-input NANDS, 2-input NANDS, and inverters.
    I came out with the following. Would you mind checking my work? This is for the function X0 only. I used the DeMorgans Theorem to use the NANDS instead or the OR.
  4. MrCarlos
    Jan 2, 2010
    400
    134
    Hello thisonedude
    You say:
    Well, I'd like to see it to check it
  5. thisonedude
    Apr 20, 2014
    52
    My schematic is attached attached to my reply post. Is it not showing up?
  6. thisonedude
    Apr 20, 2014
    52
    I have reattached the image.
  7. MrCarlos
    Jan 2, 2010
    400
    134
    Hello thisonedude
    What if you remove the red NOT gates and you add the blue wire ?
    But I do not know if your circuit meets your formulates
    You tried it ?
    thisonedude likes this.
  8. thisonedude
    Apr 20, 2014
    52
    Hi MrCarlos,
    Thank you for your help. I was able to figure out the schematic. my problem was that i had those extra NOT gates (The red ones) and i also have three extra NOT gates that i did not need to have. Thank you again for your help!
  9. MrCarlos
    Jan 2, 2010
    400
    134
    Hello thisonedude
    You say:
    Probably your schematic is similar to mine.
    Let me see, if possible.
    It could serve as a sample for other members.
    Meanwhile, I'll make a recommendation.
    There is a computer program named Boole-Deusto. Search it on google.com.
    Is NOT the eighth wonder but I have been very useful to learn.
    The point that it is not designed to handle many variables either input or output.
    I'm not selling it but I'm recommending it as a very good programming tool to develop combinational circuits, decoders, and so on.
    Anyway, with this Software (Boole-Deusto) you can develop your design with only gates
    NAND,
    NOR,
    AND & OR.
    With it, I developed you did with only NAND gates.
    All material is attached.
    Take a look.
    Please, be sure to not let us see your design.
    absf likes this.
