Boolean expression simplification
Discussion in 'Homework Help' started by KTD108, Sep 14, 2008.
  1. KTD108
    Sep 14, 2008
    Boolean expression simplification confuses me beyond belief. Please help...
    1) F=(AC+(B'D)')'(E+D')'+C
    2) F=((BD)'(E XNOR C)'+CA)'
    3) A XNOR (A+B)
    4) A XNOR B XNOR (AB)
    My hw is due tomorrow at 10, so please help!! Thanks!!
  2. hgmjr
    Jan 28, 2005
    9,030
    214
  3. KTD108
    Sep 14, 2008
    Ok, so I figured out 3 and 4...the first 2 are still confusing me tho. This is what I have for the first one...
    = ((AC)'B'D) (E+D')' + C
    = ((A'+C')B'D) (E'D) + C
    = (A'B'D + B'C'D)E'D + C
    = (A'B'DE' + B'C'DE' + C
    = B'DE'(A' + C') + C
    But I don't know how to get it so there is only 1 C term...any advice?
  4. silvrstring
    Mar 27, 2008
    159
    KTD108,
    Take your (A' + C'), and transform it to (AC)'.
    You are then left with F=(AC)'B'DE' + C.
    From there, you can apply the inverse of F to manipulate the equation so you can get C where you want it (i.e., F'=((AC)'B'DE' + C)'
    When you get it to a form that only has one of each term, you can take F'' = F to find your final simplified equation. If I'm right, you will end up with only 4 terms.
    Let us know how your progress goes.
  5. KTD108
    Sep 14, 2008
    Hmm..ok I must be doing something wrong then. I'm supposed to draw the CMOS circuit for:
    And the only way I know/understand how to draw the CMOS circuit is to simplify the equation and then draw it. I think all 5 terms should still be used though. Is there an easier way to draw the circuit without simplifying?
  6. silvrstring
    Mar 27, 2008
    159
    KTD108,
    I can't help you with the CMOS drawing, but I'll show you how I simplified the Boolean eqn. You can then look it over to see if it all adds up.
    If F = B'DE'(A' + C') + C then F = (AC)'B'DE' + C
    F' = ((AC)'B'DE' + C)' = ((AC)'B'DE')' C'
    = ((AC)'' + B'' + D' +E'') C'
    = (AC + B + D' + E) C'
    = A0 + BC' + D'C' + EC'
    = BC' + D'C' + EC'
    Now F'' = F = (BC' + D'C' + EC')' = (BC')' (D'C')' (EC')'
    = (B' + C)(D + C)(E' + C)
    = (B'D + B'C + CD + C)(E' + C)
    = B'DE' + B'DC + B'CE' + B'C + CDE' + CD + CE' + C
    = B'DE' + C(B'D +B'E' + B' +DE' + D + E' +1)
    = B'DE' + C (because Any + 1 = 1)
    The algebra makes sense, but you'll want to look over it, and make a truth table to compare to the one you started with.
    Hope this helped. Good luck on number 2.
