Boolean Expression Extraction
Discussion in 'Homework Help' started by *.*.*AnUm*.*.*, Aug 1, 2015.
  1. *.*.*AnUm*.*.*
    Apr 21, 2015
    16
    See, is my concept correct ?
    In this k map, we can't make group of three 1's because all variables are changing, if we make group of these three 1's. group of 1's we can't make is highlighted.
    Thanks!
  2. tshuck
    Oct 18, 2012
    3,531
    675
    The reason why depends on what the relationships are between the boxes in the map. Try to reduce the expression using Boolean logic and compare the results to that of the K-map - this should grant you an idea of why and how a K-map works and why it uses such an odd numbering scheme.
  3. WBahn
    Mar 31, 2012
    18,093
    4,920
    The key is in understanding what a K-map is used for. The groupings identify signals that do not matter for that grouping, meaning that if you change that variable that you don't change the output. In your grouping of three, it would appear that changing A doesn't change the output and changing B doesn't change the output. But yet if you change A and B so that both are LO, you change the output. Thus it is not a valid logic minimization.
    absf likes this.
