Boolean Expression + algebraic manipulation
Discussion in 'Math' started by mnv_smiley, Sep 11, 2007.
  1. mnv_smiley
    Sep 11, 2007
    Could some one please help me! I do not understand this algebraic manipulation and would appreciate any help.
    Prove the identity of each of the following Boolean expressions, using algebraic manipulation:
    a) ABC' + BC'D' + BC + C'D = B + C'd
    b) WY + W'YZ' + WXZ + W'XY' = WY + W'XZ' + X'YZ' + XY'Z
    c) AD' + A'B + C'D + B'C = (A'+B'+C'+D') (A + B + C + D)
    any help at all would be greatly appreciated. Even if it's just a starting hint or soemthing. :)
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Its probably best to give you some pointers first, then you can try and post up your answers so we can check.
    Check the e-book sections:
    Boolean algebraic identities
    Boolean algebraic properties
    Boolean rules for simplification
    Pointers:
    Q1) Look for common factors, and note that the CD' term is on both sides of the equation (therefore might not need touching)
    Q2) The above identifies should be useful here. Note this is more of a rearrangement exercise.
    Q3) Look at DeMorgans Theorems for this one.
    Dave
  3. mnv_smiley
    Sep 11, 2007
    I factored b out and got:
    b(ac' + c'd' + c) + c'd = b + c'd
    then since I have a c and a c' I got rid of the c and I now have:
    b(a + d') + c'd = b + c'd
  4. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Can I ask by what process you got rid of the C?
    Dave
